How can I remove the reading view button from the URL BAR
  • Akukho zimpendulo
  • 0 inale ngxaki
  • 2 views
I want to get rid of this icon.
There's an advice/suggestions going around for years based on my search, to disable the reader parse on load config.
It doesn't work, at least not on Android.
And then, we have this other horrible icon for translation. I can't remove that either.
I don't know what exactly developers think but the URL BAR is to show the URL, and smartphone screen size is limited. If that's not the case, just rename it to something like "random enabled features button bar" or something.
I want to get rid of this icon. There's an advice/suggestions going around for years based on my search, to disable the reader parse on load config. It doesn't work, at least not on Android. And then, we have this other horrible icon for translation. I can't remove that either. I don't know what exactly developers think but the URL BAR is to show the URL, and smartphone screen size is limited. If that's not the case, just rename it to something like "random enabled features button bar" or something.
Iqhotyoshelwe imifanekiso ekwisikrini
